[mapguide-users] MapAgent problems
Kenneth, GEOGRAF A/S ks at geograf.dk
Mon Oct 8 10:39:48 EDT 2007
Another likely cause is that the MapAgent.fcgi or MapAgent.exe is not
allowed to run.
You can adjust settings for that under the "Extensions" node in IIS.
Regards, Kenneth, GEOGRAF A/S
rudy.pavan skrev:
> Hello Kenneth,
> I have tried your solution,but the problems continue.
> Rudy
> I have seen installations where the FCGI is broken.
> Try using this link instead:
> http://localhost/mapguide/mapagent/mapagent.exe?
> OPERATION=ENUMERATERESOURCES&VERSION=1.0.0&LOCALE=en&RESOURCEID=Library
> ://&TYPE=MapDefinition&DEPTH=-1
> Also, MapGuide EP is using another path:
> http://localhost/mapguide2008/mapagent/mapagent.exe?
> rudy.pavan skrev:
>> Hello Andy,
>> if I refresh my browser the situation doesn't change.
>> The other sample application (ajaxviewersample.aspx) have the same
>> problems.
>> I've another problem: when I try to load
>> http://localhost/mapguide/mapagent/mapagent.fcgi?
>> ://&TYPE=MapDefinition&DEPTH=-1 (for testing the MapAgent) the
>> response is "page not found"
>> Note: - I've installed MGOS (on Windows 2003 Server EE R2 with
> IIS
>> 6.0) using the installer programs
>>       - http://localhost/mapguide/mapadmin/login.php  is ok
>>       - http://localhost/mapguide/mapagent/index.html is ok
>> Rudy
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071008/3b4266b4/attachment.html
