[mapguide-users] Problem of printing Right To left Direction
inAJEX viewer
Traian Stanev
traian.stanev at autodesk.com
Tue Oct 9 11:21:30 EDT 2007
Hi Ori,
You could use a GetPlot request, which will return a DWF file of a given
map view. You can then print the returned DWF file.
However, if you also generate a legend image, that is rendered server
side and uses the same pipeline as the AJAX viewer so strings in the
legend image will still be inverted.
Traian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
> bounces at lists.osgeo.org] On Behalf Of ori gudes
> Sent: Tuesday, October 09, 2007 10:38 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Problem of printing Right To left Direction
> inAJEX viewer
> Hi Colleagues
> Due to a problem of printing Right To left Direction (Hebrew) with the
> AJAX
> viewer, it makes the characters shown opposite when printing. I
> consider
> implementing another method of printing (Printing based on DWF
format).
> I
> would like to know more information about implementing Printing based
> on
> DWF.
> Help will be appreciated.
> Thanks in advance Ori
> View this message in context: http://www.nabble.com/Problem-of-
> printing-Right-To-left-Direction-in-AJEX-viewer-
> tf4594614s16610.html#a13116862
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
