[mapguide-users] Problem of printing Right To left Direction inAJEX viewer
Nimrod Cnaan nimcnaan at hotmail.com
Tue Oct 9 14:14:47 EDT 2007
To Traian
Sorry Traian but I think you are wrong. The legend's text is reversed only when using the GETMAPLEGENDIMAGE, but when plotting the same map using
GeneratePlot function the Hebrew text is fine.
p.s.
I'm using the function - OutputReaderContent(Response, byteReader), from utilityfunctions.aspx
To Ori
you can use the 'plot to dwf' sample found in the dotnetviewersample
Nimrod Cnaan
Senior GIS programmer
972525355483
> Subject: RE: [mapguide-users] Problem of printing Right To left Direction inAJEX viewer> Date: Tue, 9 Oct 2007 11:21:30 -0400> From: traian.stanev at autodesk.com> To: mapguide-users at lists.osgeo.org> > Hi Ori,> > You could use a GetPlot request, which will return a DWF file of a given> map view. You can then print the returned DWF file.> However, if you also generate a legend image, that is rendered server> side and uses the same pipeline as the AJAX viewer so strings in the> legend image will still be inverted.> > > Traian> > > > -----Original Message-----> > From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-> > bounces at lists.osgeo.org] On Behalf Of ori gudes> > Sent: Tuesday, October 09, 2007 10:38 AM> > To: mapguide-users at lists.osgeo.org> > Subject: [mapguide-users] Problem of printing Right To left Direction> > inAJEX viewer> > > > > > Hi Colleagues> > > > > > Due to a problem of printing Right To left Direction (Hebrew) with the> > AJAX> > viewer, it makes the characters shown opposite when printing. I> > consider> > implementing another method of printing (Printing based on DWF> format).> > I> > would like to know more information about implementing Printing based> > on> > DWF.> > > > Help will be appreciated.> > > > Thanks in advance Ori> > > > --> > View this message in context: http://www.nabble.com/Problem-of-> > printing-Right-To-left-Direction-in-AJEX-viewer-> > tf4594614s16610.html#a13116862> > Sent from the MapGuide Users mailing list archive at Nabble.com.> > > > _______________________________________________> > mapguide-users mailing list> > mapguide-users at lists.osgeo.org> > http://lists.osgeo.org/mailman/listinfo/mapguide-users> > > _______________________________________________> mapguide-users mailing list> mapguide-users at lists.osgeo.org> http://lists.osgeo.org/mailman/listinfo/mapguide-users
_________________________________________________________________
Invite your mail contacts to join your friends list with Windows Live Spaces. It's easy!
http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx&mkt=en-us
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071009/ebbaed75/attachment.html
