[mapguide-users] Exmple of Gdal index xml
Gary Morin
gary.morin at keygis.co.uk
Wed Oct 10 12:58:01 EDT 2007
Hi
I'm back in the office and I have been doing more research into the problem
I'm getting with configuration files. I have repeated the problem on other
MGOS servers.
I have tracked the problem down to being releated to the bounds specfied in
schemamapping for each image. If I remove the bounds tag(s) and also change
the name in sechmemapping away from defualt tag the config file will work.
It also works if I replace the bounds with Georeference tag to a degree,
although I have not got the positioning correctly.
Below I have included the schema that fails and one that partially works.
Regards
Gary
Sample produces using bounds that gives and error, if
<fdo:DataStore xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:gml="http://www.opengis.net/gml"
xmlns:fdo="http://fdo.osgeo.org/schemas"
xmlns:fds="http://fdo.osgeo.org/schemas/fds">
<gml:DerivedCRS gml:id="Default">
<gml:metaDataProperty>
<gml:GenericMetaData>
<fdo:SCExtentType>dynamic</fdo:SCExtentType>
<fdo:XYTolerance>0.001000</fdo:XYTolerance>
<fdo:ZTolerance>0.001000</fdo:ZTolerance>
</gml:GenericMetaData>
</gml:metaDataProperty>
<gml:remarks>System generated default FDO Spatial
Context</gml:remarks>
<gml:srsName>Default</gml:srsName>
<gml:validArea>
<gml:boundingBox>
<gml:pos>394999.25242 424999.31774</gml:pos>
<gml:pos>425000.48226 455000.56758</gml:pos>
</gml:boundingBox>
</gml:validArea>
<gml:baseCRS>
<fdo:WKTCRS gml:id="Default">
<fdo:WKT>LOCAL_CS["*XY-MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter",
1],AXIS["X",EAST],AXIS["Y",NORTH]]</fdo:WKT>
</fdo:WKTCRS>
</gml:baseCRS>
<gml:definedByConversion
xlink:href="http://fdo.osgeo.org/coord_conversions#identity"/>
<gml:derivedCRSType
codeSpace="http://fdo.osgeo.org/crs_types">geographic</gml:derivedCRSType>
<gml:usesCS xlink:href="http://fdo.osgeo.org/cs#default_cartesian"/>
</gml:DerivedCRS>
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns:default="http://fdo.osgeo.org/schemas/feature/default"
targetNamespace="http://fdo.osgeo.org/schemas/feature/default"
elementFormDefault="qualified" attributeFormDefault="unqualified">
<xs:annotation>
<xs:appinfo source="http://fdo.osgeo.org/schemas"/>
</xs:annotation>
<xs:element name="default" type="default:defaultType"
abstract="false" substitutionGroup="gml:_Feature">
<xs:key name="defaultKey">
<xs:selector xpath=".//default"/>
<xs:field xpath="FeatId"/>
</xs:key>
</xs:element>
<xs:complexType name="defaultType" abstract="false"
fdo:hasGeometry="false">
<xs:annotation>
</xs:annotation>
<xs:complexContent>
<xs:extension base="gml:AbstractFeatureType">
<xs:sequence>
<xs:element name="FeatId">
<xs:annotation>
<xs:appinfo
</xs:annotation>
<xs:simpleType>
<xs:restriction base="xs:string">
<xs:maxLength value="256"/>
</xs:restriction>
</xs:simpleType>
</xs:element>
<xs:element name="Image"
type="fdo:RasterPropertyType" fdo:defaultImageXSize="1024"
fdo:defaultImageYSize="1024" fdo:srsName="Default">
<xs:annotation>
<xs:appinfo
source="http://fdo.osgeo.org/schemas">
<fdo:DefaultDataModel
dataModelType="Bitonal" dataType="Unknown" organization="Pixel"
bitsPerPixel="1" tileSizeX="256" tileSizeY="256"/>
</xs:appinfo>
</xs:annotation>
</xs:element>
</xs:sequence>
</xs:extension>
</xs:complexContent>
</xs:complexType>
</xs:schema>
<SchemaMapping xmlns="http://fdogrfp.osgeo.org/schemas"
provider="OSGeo.Gdal.3.2" name="default">
<complexType name="defaultType">
<complexType name="RasterTypeType">
<RasterDefinition name="images">
<Location name="D:\Projects\MGDemo\Raster\">
<Feature name="Sd93ne.tif">
<Band name="RGB" number="1">
<Image frame="1" name="Sd93ne.tif">
<Bounds>
<MinX>394999.25242</MinX>
<MinY>434999.31774</MinY>
<MaxX>400000.50226</MaxX>
<MaxY>440000.56758</MaxY>
</Bounds>
</Image>
</Band>
</Feature>
</Location>
</RasterDefinition>
</complexType>
</complexType>
</SchemaMapping>
</fdo:DataStore>
Sample of config that partially works
<gml:validArea>
<gml:boundingBox>
<gml:pos>394999.0 430000.0</gml:pos>
<gml:pos>405000.0 450000.0</gml:pos>
</gml:boundingBox>
</gml:validArea>
<gml:baseCRS>
</fdo:WKTCRS>
</gml:baseCRS>
<gml:derivedCRSType
</gml:DerivedCRS>
<xs:annotation>
</xs:annotation>
</xs:key>
</xs:element>
<xs:annotation>
</xs:annotation>
<xs:complexContent>
<xs:sequence>
<xs:annotation>
<xs:appinfo
</xs:annotation>
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:element>
<xs:annotation>
<xs:appinfo
</xs:appinfo>
</xs:annotation>
</xs:element>
</xs:sequence>
</xs:extension>
</xs:complexType>
</xs:schema>
provider="OSGeo.Gdal.3.2" name="Raster">
<complexType name="rasterTypeType">
<Georeference>
<InsertionPointX>394999.57000</InsertionPointX>
<InsertionPointY>440000.25000</InsertionPointY>
<ResolutionX>0.635160</ResolutionX>
<ResolutionY>0.635160</ResolutionY>
<RotationX>0</RotationX>
<RotationY>0</RotationY>
</Georeference>
</Image>
</Band>
</Feature>
</Location>
</RasterDefinition>
</complexType>
</complexType>
</SchemaMapping>
</fdo:DataStore>
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: 04 October 2007 20:11
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Exmple of Gdal index xml
Understood. I can't see anything wrong with that latest config file
though. It almost seems like your server isn't sending the entire
config to Studio. Can you try creating a layer without testing the data
source and see if it works?
Also maybe try stopping/restarting the MapGuide the server and
restarting studio?
Jason
If I delete the configuration file the feature source works okay and the
contents can be displayed. However as soon as I upload the generated
configuration file I get the same errors as before.
As we may be working with many images it would make sense to optimize
the configuration.
Thanks for your assistance
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
