[mapguide-users] Exmple of Gdal index xml
Jason Birch
Jason.Birch at nanaimo.ca
Wed Oct 10 15:44:41 EDT 2007
That's just bizarre Gary. Are you absolutely sure that you are running
1.2 final? The bounds support was not included in earlier betas and
release candidates.
If you want to provide me with some of your images, I could try setting
up a configuration here? Might take me a while.
Jason
-----Original Message-----
Subject: RE: [mapguide-users] Exmple of Gdal index xml
repeated the problem on other MGOS servers.
I have tracked the problem down to being releated to the bounds specfied
in schemamapping for each image. If I remove the bounds tag(s) and also
change the name in sechmemapping away from defualt tag the config file
will work.
It also works if I replace the bounds with Georeference tag to a degree,
although I have not got the positioning correctly.
