[mapguide-users] Exmple of Gdal index xml
Gary Morin
gary.morin at keygis.co.uk
Wed Oct 10 16:10:04 EDT 2007
Hi Jason
That's what I starting to think, I'm sure it was 1.2 final I downloaded and
installed. But looking in the fdo providers.xml it seems to be referencing
3.2.2 and not 3.2.3
I'm using version 1.2.0.1801 what release is it?
I have just tried downloading MG again but I'm having problems with the
website downloads don't seem to be working.
Regards
Gary
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: 10 October 2007 20:45
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Exmple of Gdal index xml
That's just bizarre Gary. Are you absolutely sure that you are running
1.2 final? The bounds support was not included in earlier betas and
release candidates.
If you want to provide me with some of your images, I could try setting
up a configuration here? Might take me a while.
Jason
repeated the problem on other MGOS servers.
I have tracked the problem down to being releated to the bounds specfied
in schemamapping for each image. If I remove the bounds tag(s) and also
change the name in sechmemapping away from defualt tag the config file
will work.
It also works if I replace the bounds with Georeference tag to a degree,
although I have not got the positioning correctly.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
