[mapguide-users] MG Enterprise and Open-Source in one server
m.karam m21384k at yahoo.com
Mon Oct 15 13:09:05 EDT 2007
thanks
I will try it and return back to you
Regards
Karam
Christy Nieman wrote:
> <MG install directory>\Server\Bin\serverconfig.ini and <MG install
> directory>\WebServerExtensions\www\webconfig.ini were the ini files that
> we edited.  You have to change the [AdministrativeConnectionProperties],
> [ClientConnectionProperties] and [SiteConnectionProperties] ports in
> these two files for one of the installs.
> Christy
> Paul Spencer wrote:
>> I believe we had to change the port numbers used by MapGuide
>> Enterprise (or conversely by MGOS) to communicate with the web tier.
>> You need to edit some ini file (can't remember which) in the server
>> and webserverextensions in one installation and change three
>> consecutive port numbers to new values.
>> Cheers
>> Paul
>> On 15-Oct-07, at 12:36 PM, Andy Morsell wrote:
>>> Yes, that should work fine.  By default, MGE 2008 uses a different
>>> virtual
>>> directory (alias) of mapguide2008 and runs under a different Windows
>>> service
>>> name.
>>> Andy Morsell, P.E.
>>> Spatial Integrators, Inc.
>>> http://www.SpatialGIS.com
>>> -----Original Message-----
>>> From: mapguide-users-bounces at lists.osgeo.org
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of m.karam
>>> Sent: Monday, October 15, 2007 7:46 AM
>>> To: mapguide-users at lists.osgeo.org
>>> Subject: [mapguide-users] MG Enterprise and Open-Source in one server
>>> Hi Everybody
>>> Can I install (Autodesk MapGuide Enterprise 2008) and (MapGuide
>>> Open-Source
>>> 1.2) in one server?
>>> Thanks in advance
>>> Karam
>>> View this message in context:
>>> http://www.nabble.com/MG-Enterprise-and-Open-Source-in-one-server-tf4627985s
>>> 16610.html#a13214227
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> |Paul Spencer                          pspencer at dmsolutions.ca    |
>> |Chief Technology Officer                                         |
>> |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
View this message in context: http://www.nabble.com/MG-Enterprise-and-Open-Source-in-one-server-tf4627985s16610.html#a13217315
