[mapguide-users] MapGuide Automated Tiling Engine 1.2 -patchedrelease
Kori Maleski Kori.Maleski at websoftdev.com
Mon Oct 15 14:28:39 EDT 2007
Hi Krunoslav,
The error seems to be the same as from the previous release.  Can you please
uninstall the application and download and reinstall the current release and
let me know if it persists?  Perhaps empty your browsers cache first as
well.  Maybe something went wrong with the install.
I have tested the application on a Non-earth arbitrary XY coordinate system
this morning and it is tiling correctly.
Let me know if the error persists.
Cheers,
Kori Maleski
Senior Application Developer
WEBSOFT DEVELOPERS, INC.
P: (530) 759-8754 ext 114
F: (530) 759-0923
kori.maleski at websoftdev.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Krunoslav
Sent: Sunday, October 14, 2007 10:22 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] MapGuide Automated Tiling Engine 1.2
-patchedrelease
Kori Maleski-4 wrote:
> Are the scales you are using the same as in the Map Definition in Studio?
> If you run it without specify a scale does it throw the same errors?
Of course they are the same: I am running it without any parameter:
C:\Program Files\Websoft Developers\FacilitiesMap Tiling
Engine>FmTilingEngine.e
xe -u Administrator -p admin
Preparing to Tile 'map1' Map Definition...
Initializing Connection to MapGuide...Succeeded
Tiling 'Orto' Layer Group...
 Scale: 1:5000   Finite Scale 1 of 3
 Tiles: 9 ( 3 Columns x 3 Rows )
 ...1...2...3...4...5...6...7...8...9                   100%
 Scale: 1:2000   Finite Scale 2 of 3
 Scale: 1:1000   Finite Scale 3 of 3
Tiling Complete
But, as I wrotebefore, tiles are not being made due to Errors. Should I try
to change some parameters regarding tile size and format in
serverconfig.ini?
View this message in context:
http://www.nabble.com/MapGuide-Automated-Tiling-Engine-1.2---patched-release
-tf4616105s16610.html#a13206887
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
