[mapguide-users] Adding layers permanent - I found my mistake
peter56 ibb.scigalla at arcor.de
Tue Oct 16 09:03:10 EDT 2007
Dear all,
sorry, I found my mistake. The wrong line was:
$resourceId = new
MgResourceIdentifier("Library://LayerName.LayerDefinition");
The correct line is:
$resourceId = new
MgResourceIdentifier("Library://projekt/layer/alle.LayerDefinition");
Regards - Peter
peter56 wrote:
> Dear all,
> based on the example in the Developer's Guide, I created a new Layer to
> the map at runtime:
>     // Neuen MG-Layer definieren
>     $featureClass = 'Library://projekt/'
>       . 'mysql.FeatureSource';
>     $featureName = 'Fdotest:agmg_wasleitung';
>     $geometry = 'graphik';
> 	$layerDefinition = $factory->
> 	  CreateLayerDefinition($featureClass, $featureName,
> 	  $geometry, $lineScaleRange);
>     // in die Karte einfügen
>     $newLayer = add_layer_definition_to_map($layerDefinition, "alle",
> "alle", $sessionId, $resourceService, $map);
>     add_layer_to_group($newLayer, "Analysis", "Analysis", $map);
>     // jetzt sichtbar machen
>     $layerCollection = $map->GetLayers();
>     if ($layerCollection->Contains("alle"))
>         $squareFootageLayer =$layerCollection->GetItem("alle");
>         $squareFootageLayer->SetVisible(TRUE);
>       //  im session repository speichern
>       $sessionIdName = "Session:$sessionId//$mapName.Map";
>       $sessionResourceID = new MgResourceIdentifier($sessionIdName);
>       $sessionResourceID->Validate();
>       $map->Save($resourceService, $sessionResourceID);
> It works fine. (Very thanks to all writers of the Developer's Guide!) Now
> I have only one problem:
> I tried to make the changes permanent using the code from Developer's
> Guide, but nothing happens:
>     // jetzt nach Handbuch Kapitel 4, Seite 66 den Layer in die Datenbank
> schreiben
>     $byteSource = new MgByteSource($layerDefinition,
> strlen($layerDefinition));
>     $byteSource->SetMimeType(MgMimeType::Xml);
>     $resourceId = new
>     $resourceService->SetResource($resourceId, $byteSource->GetReader(),
> null);
> What am I doing wrong?
> Regards - Peter
View this message in context: http://www.nabble.com/Adding-layers-permanent-tf4633765s16610.html#a13233231
