[mapguide-users] Databases PostGIS/ ArcSDE / Oracle spatial
Berdel, Brian
brian.berdel at mcmtrans.com
Wed Oct 17 14:32:53 EDT 2007
Found this... MsSqlSpatial - Spatial Extensions for SQL Server 2005
Anyone have any experience with it?
Brian Berdel
McMahon Associates, Inc.
p: 215.283.9444
www.mcmtrans.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Berdel,
Brian
Sent: Wednesday, October 17, 2007 2:04 PM
To: MapGuide Users Mail List
Subject: [mapguide-users] Databases PostGIS/ ArcSDE / Oracle spatial
We are going to migrate everything into spatial databases, but I wanted
to get some feedback from the group if possible on your experiences with
the different products. We currently have SQL 2005 and I am very
comfortable with it, from what I can tell the only spatial product that
is compatible is
ArcSDE. Is that true? Also, I believe you need to purchase the full
ArcGIS server suite now.
Secondly how is PostGIS / PostgreSQL? Pro's Con's?
I develop in .NET so I would like to use SQL 2005 if possible.
Brian Berdel
p: 215.283.9444
www.mcmtrans.com
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Traian
Stanev
Sent: Wednesday, October 17, 2007 1:56 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] duplicate labels
If you have long polylines, they may get labeled several times with a
spacing of a few hundred pixels between labels. May be this is what you
are seeing.
Inverted labels should be rare -- only if you have circular or nearly
circular polylines in your layer. Even then the code in 1.2 will try to
avoid that as much as possible. Since labels follow the curve of the
polylines, it can happen that one piece of the label is pointing up
while another is pointing down. Again, I'm just guessing here since you
did not give enough detail.
Traian
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
> bounces at lists.osgeo.org] On Behalf Of AJim
> Sent: Wednesday, October 17, 2007 1:17 PM
> Subject: [mapguide-users] duplicate labels
> Hi,
> Newbie trying to use 1.2 with street maps. We seem to be getting
> duplicate
> labels and upside down labels displayed. The source was imported from
> a
> shapefile. Not using any tiling features.
> Any ideas?
> Thanks
> AJ
> View this message in context: http://www.nabble.com/duplicate-labels-
> tf4630604s16610.html#a13222479
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
