[mapguide-users] MGOS 2.0...
Zac Spitzer zac.spitzer at gmail.com
Fri Oct 19 00:45:30 EDT 2007
pick one? these two are closely related :)
Failing Layer filters are a nightmare at the moment, there is no
feedback at all...
This is so the users can tell us it failing, i consider it a severe
bug (ie wrong data!!!) , unless your just using mapguide to render
whole datasets as static maps
> When a layer filter fails layer should be rendered empty
> http://trac.osgeo.org/mapguide/ticket/289
This is so the sys admin knows it
> Failed Layer Filters should be logged to error.log
> http://trac.osgeo.org/mapguide/ticket/254
On 10/19/07, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
> So, if you had to pick one, which would it be, and why?
> Jason
> ________________________________
> From: Zac Spitzer
> Subject: Re: [mapguide-users] MGOS 2.0...
> Here are my top 5
> ResourceExists returns "not implemented"
> http://trac.osgeo.org/mapguide/ticket/288
> Improve speed of rendering engine by not using "select * from table"
> http://trac.osgeo.org/mapguide/ticket/272
> Adding to Unmanaged Datasources Not Available until Server Restart
> http://trac.osgeo.org/mapguide/ticket/86
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
http://zacster.blogspot.com/
+61 405 847 168 (aussie moible)
