[mapguide-users] MGOS 2.0...
Jason Birch Jason.Birch at nanaimo.ca
Fri Oct 19 01:00:53 EDT 2007
OK, I guess one and a half :)
I was initially thinking that this would only be a problem when initially setting up the map and would have ranked it as a fairly low priority because of that, but I guess if you let the users define the filters at runtime, then it's a real issue.  Is this where you're seeing the problem?  Can you provide details about a real-world scenario on the ticket?  Providing information on why this is a pain point really helps when prioritising  the issues.
Jason
Subject: Re: [mapguide-users] MGOS 2.0...
pick one? these two are closely related :)
Failing Layer filters are a nightmare at the moment, there is no
feedback at all...
This is so the users can tell us it failing, i consider it a severe
bug (ie wrong data!!!) , unless your just using mapguide to render
whole datasets as static maps
> When a layer filter fails layer should be rendered empty
> http://trac.osgeo.org/mapguide/ticket/289
This is so the sys admin knows it
> Failed Layer Filters should be logged to error.log
> http://trac.osgeo.org/mapguide/ticket/254
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071018/5c407f0e/attachment.bin
