[mapguide-users] Mapguide and Oracle: The remote server returnedan error: (559) MgFdoException
Haris Kurtagic haris at sl-king.com
Fri Oct 19 05:11:10 EDT 2007
King.Oracle and King.MsSqlSpatial are Open Source. Source code is in a
FDO SVN http://svn.osgeo.org/fdo/trunk/Providers/KingOracle/.
Memory leak is fixed.
Layer filter problem ? I am not aware of it, If you can give me some
more info would be great.
Haris
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Wednesday, October 17, 2007 6:07 PM
To: CDM - Federica De Martin; MapGuide Users Mail List
Subject: Re: [mapguide-users] Mapguide and Oracle: The remote server
Be aware that there are some issues with layer filters not working
with King.Oracle
I'm not 100% sure but 0.7.3 works better with the oracle instant
client from http://www.sl-king.com/fdooracle than the full oracle
client, there was some issues with a memory leak.
At some point Harris was going to open source King.Oracle
Here is a working feature source example.
<?xml version="1.0" encoding="ISO-8859-1"?>
<FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
   <Provider>King.Oracle</Provider>
   <Parameter>
      <Name>Username</Name>
      <Value>PSMA_AUG_07</Value>
   </Parameter>
   <Parameter>
      <Name>Password</Name>
      <Value>moenkey77455secret</Value>
   </Parameter>
   <Parameter>
      <Name>Service</Name>
      <Value>ZAC</Value>
   </Parameter>
   <Parameter>
      <Name>OracleSchema</Name>
   </Parameter>
</FeatureSource>
On 10/18/05, CDM - Federica De Martin <tecnico at gpingegneria.it> wrote:
> Hi!
> I have got some problems loading data with MapGuide Open Source. First
of
> all I have WindowsXP and I'm using MapGuide Studio Preview version and
I try
> to connect to Oracle database.
> If I try to use:
> "OSGEO Fdo Provider for SHP" everything's ok (Connection
Successfull...);
> "OSGEO Fdo Provider for Raster" Connection is Successfull  but then I
cannot
> view the data in a layer or map preview;
> "OSGEO Fdo Provider for ODBC" I cannot connect to any data type (not
only
> Oracle) and I always get:
>    System.Net.WebException: The remote server returned an error: (559)
> MgFdoException.
>       in
Autodesk.MapGuide.Studio.Site.Comm.RequestManager.ExecutePendingGetReque
stToString(Operation
> operation)
>       in
Autodesk.MapGuide.Studio.Site.Comm.RequestManager.TestConnection(String
> resourceId, String provider, String connectionString)
>       in
> Autodesk.MapGuide.Studio.Site.FeatureSourceInfo.TestConnection()
>       in
Autodesk.MapGuide.Studio.UI.FeatureSourceEditors.TestConnectionControl.b
uttonTestConnection_Click(Object
> sender, EventArgs e)
> I've controlled in
> c:\programmi\MapGuideOpenSource\Server\Bin\FDO\provider.xml
> and the ODBC provider is correctly listed.
> I get the same error if I try to connect with "King provider for
Oracle".
> In my opinion it isn't a problem of parameters but I've tried so many
> combination that now I'm not still so sure... it would be also useful
> if someone can tell me how parameters had to be set. This is an
example of
> mine:
>       <FeatureSource
>         <Provider>OSGeo.ODBC.3.2</Provider>
>         <Parameter>
>           <Name>UserId</Name>
>           <Value>gis</Value>
>         </Parameter>
>         <Parameter>
>           <Value>gis</Value>
>         </Parameter>
>         <Parameter>
>           <Name>DataSourceName</Name>
>           <Value>ubuntuXE</Value>
>         </Parameter>
>         <Parameter>
>           <Name>ConnectionString</Name>
>           <Value></Value>
>         </Parameter>
>         <Parameter>
>           <Name>GenerateDefaultGeometryProperty</Name>
>           <Value></Value>
>         </Parameter>
>       </FeatureSource>
> I hope someone has already faced this problem and can help me to make
it
> work!
> Thank you all.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
http://zacster.blogspot.com/
+61 405 847 168 (aussie moible)
