[mapguide-users] MGOS 2.0...
Campbell, Keith A
keith.campbell at atkinsglobal.com
Fri Oct 19 05:06:00 EDT 2007
I agree with Zac, even for development, this can be very frustrating and
a big time-waster.
I think this is also important, and related:-
http://trac.osgeo.org/mapguide/ticket/243
Keith
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: 19 October 2007 06:26
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] MGOS 2.0...
I think in terms of mapguide being developer friendly this is *really*
important.
A use-case like a contractor assignment application where the contractor
logs in and is meant to see their assigned jobs on the map (via a
filter) can lead to some fairly serious business problems, lost time,
two contractors turning up to the same job etc.
Any mapguide application which has completely separate customer
business's cannot currently be guaranteed that their data is private.
I hit this error because the King.Oracle driver fails a lot with layer
filters, but beyond monitoring SQL on the database there is no feedback,
beyond maybe seeing too much data.
As an out of the box experience for someone evaluating mapguide, i would
find this very frustrating and I could imagine wasting hours because of
this problem.
So that's why i think's it important... (text copied to the bug)
z
On 10/19/07, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
> OK, I guess one and a half :)
> I was initially thinking that this would only be a problem when
initially setting up the map and would have ranked it as a fairly low
priority because of that, but I guess if you let the users define the
filters at runtime, then it's a real issue. Is this where you're seeing
the problem? Can you provide details about a real-world scenario on the
ticket? Providing information on why this is a pain point really helps
when prioritising the issues.
> Jason
> ________________________________
> From: Zac Spitzer
> pick one? these two are closely related :)
> Failing Layer filters are a nightmare at the moment, there is no
> feedback at all...
> This is so the users can tell us it failing, i consider it a severe
> bug (ie wrong data!!!) , unless your just using mapguide to render
> whole datasets as static maps
> > When a layer filter fails layer should be rendered empty
> > http://trac.osgeo.org/mapguide/ticket/289
> This is so the sys admin knows it
> > Failed Layer Filters should be logged to error.log
> > http://trac.osgeo.org/mapguide/ticket/254
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
http://zacster.blogspot.com/
+61 405 847 168 (aussie moible)
This message has been scanned for viruses by MailControl - (see
http://bluepages.wsatkins.co.uk/?6875772)
This email and any attached files are confidential and copyright protected. If you are not the addressee, any dissemination of this communication is strictly prohibited. Unless otherwise expressly agreed in writing, nothing stated in this communication shall be legally binding.
The ultimate parent company of the Atkins Group is WS Atkins plc. Registered in England No. 1885586. Registered Office Woodcote Grove, Ashley Road, Epsom, Surrey KT18 5BW.
Consider the environment. Please don't print this e-mail unless you really need to.
