[mapguide-users] Building MGOS 1.2 on Ubuntu Server 7.04
Jason Birch
Jason.Birch at nanaimo.ca
Fri Oct 19 12:40:34 EDT 2007
You're not going to be able to install to /usr/local as an unpriveleged
user; you'll need to su to root for that operation.
Regardless, that's probably not your problem. According to some helpful
folks on #gdal you may have to install python-dev, or figure out how to
disable Python in the MapGuide build process.
Jason
-----Original Message-----
Subject: [mapguide-users] Building MGOS 1.2 on Ubuntu Server 7.04
I am running the install as a user.
In the attached NoteInstall.txt you can find what appears on my
terminal.(on Ubuntu Server 6.06). On Ubuntu Server 7.04 this not happen
(but the mapguideserver there isn't).
