[mapguide-users] Databases PostGIS/ ArcSDE / Oracle spatial
shreepad shreepadr at valuecad.com
Fri Oct 19 14:55:02 EDT 2007
Hi
i had exact same situation. i have developed using sde as well as oracle
spatial.
mge 2007 works fine on both.
i have following versions of sde and oracle i find the speed is good
sde 9.1 as still 9.2 verison does not connect to mge correctly lots of
issues
oracle 10.2 use kings fdo (nice FDO).
i have developed everything using .net (c#) works fine
thanks
shreepad
Berdel, Brian wrote:
> We are going to migrate everything into spatial databases, but I wanted
> to get some feedback from the group if possible on your experiences with
> the different products. We currently have SQL 2005 and I am very
> comfortable with it, from what I can tell the only spatial product that
> is compatible is
> ArcSDE.  Is that true?  Also, I believe you need to purchase the full
> ArcGIS server suite now.
> Secondly how is PostGIS / PostgreSQL? Pro's Con's?
> I develop in .NET so I would like to use SQL 2005 if possible.
> Brian  Berdel
> McMahon Associates, Inc.
> p: 215.283.9444
> www.mcmtrans.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Traian
> Stanev
> Sent: Wednesday, October 17, 2007 1:56 PM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] duplicate labels
> If you have long polylines, they may get labeled several times with a
> spacing of a few hundred pixels between labels. May be this is what you
> are seeing.
> Inverted labels should be rare -- only if you have circular or nearly
> circular polylines in your layer. Even then the code in 1.2 will try to
> avoid that as much as possible. Since labels follow the curve of the
> polylines, it can happen that one piece of the label is pointing up
> while another is pointing down. Again, I'm just guessing here since you
> did not give enough detail.
> Traian
>> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
>> bounces at lists.osgeo.org] On Behalf Of AJim
>> Sent: Wednesday, October 17, 2007 1:17 PM
>> Subject: [mapguide-users] duplicate labels
>> Hi,
>> Newbie trying to use 1.2 with street maps.  We seem to be getting
>> duplicate
>> labels and upside down labels displayed.  The source was imported from
>> a
>> shapefile.  Not using any tiling features.
>> Any ideas?
>> Thanks
>> AJ
>> View this message in context: http://www.nabble.com/duplicate-labels-
>> tf4630604s16610.html#a13222479
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/duplicate-labels-tf4630604s16610.html#a13300882
