[mapguide-users] duplicate labels
AJim ajgogo at gmail.com
Wed Oct 17 18:09:55 EDT 2007
The polylines are not long.  This is street data from one of the commercial
providers.  These maps are labeled ok when I look in either ArcMap or
MapInfo.
Attached is an example.
Traian Stanev wrote:
> If you have long polylines, they may get labeled several times with a
> spacing of a few hundred pixels between labels. May be this is what you
> are seeing.
> Inverted labels should be rare -- only if you have circular or nearly
> circular polylines in your layer. Even then the code in 1.2 will try to
> avoid that as much as possible. Since labels follow the curve of the
> polylines, it can happen that one piece of the label is pointing up
> while another is pointing down. Again, I'm just guessing here since you
> did not give enough detail.
> Traian
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
>> bounces at lists.osgeo.org] On Behalf Of AJim
>> Sent: Wednesday, October 17, 2007 1:17 PM
>> To: mapguide-users at lists.osgeo.org
>> Subject: [mapguide-users] duplicate labels
>> Hi,
>> Newbie trying to use 1.2 with street maps.  We seem to be getting
>> duplicate
>> labels and upside down labels displayed.  The source was imported from
>> a
>> shapefile.  Not using any tiling features.
>> Any ideas?
>> Thanks
>> AJ
>> View this message in context: http://www.nabble.com/duplicate-labels-
>> tf4630604s16610.html#a13222479
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
http://www.nabble.com/file/p13264093/testmap.jpg
View this message in context: http://www.nabble.com/duplicate-labels-tf4630604s16610.html#a13264093
