[mapguide-users] duplicate labels
Traian Stanev traian.stanev at autodesk.com
Wed Oct 17 22:15:48 EDT 2007
The attachment didn't make it...
	-----Original Message-----
	From: mapguide-users-bounces at lists.osgeo.org on behalf of AJim
	Sent: Wed 10/17/2007 6:09 PM
	To: mapguide-users at lists.osgeo.org
	Cc:
	Subject: RE: [mapguide-users] duplicate labels
	The polylines are not long.  This is street data from one of the commercial
	providers.  These maps are labeled ok when I look in either ArcMap or
	MapInfo.
	Attached is an example.
	Traian Stanev wrote:
	> If you have long polylines, they may get labeled several times with a
	> spacing of a few hundred pixels between labels. May be this is what you
	> are seeing.
	> Inverted labels should be rare -- only if you have circular or nearly
	> circular polylines in your layer. Even then the code in 1.2 will try to
	> avoid that as much as possible. Since labels follow the curve of the
	> polylines, it can happen that one piece of the label is pointing up
	> while another is pointing down. Again, I'm just guessing here since you
	> did not give enough detail.
	> Traian
	>> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
	>> bounces at lists.osgeo.org] On Behalf Of AJim
	>> Sent: Wednesday, October 17, 2007 1:17 PM
	>> Subject: [mapguide-users] duplicate labels
	>> Hi,
	>> Newbie trying to use 1.2 with street maps.  We seem to be getting
	>> duplicate
	>> labels and upside down labels displayed.  The source was imported from
	>> a
	>> shapefile.  Not using any tiling features.
	>> Any ideas?
	>> Thanks
	>> AJ
	>> View this message in context: http://www.nabble.com/duplicate-labels-
	>> tf4630604s16610.html#a13222479
	>> Sent from the MapGuide Users mailing list archive at Nabble.com.
	>> mapguide-users mailing list
	>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
	http://www.nabble.com/file/p13264093/testmap.jpg
	View this message in context: http://www.nabble.com/duplicate-labels-tf4630604s16610.html#a13264093
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071017/49ab5769/attachment.html
