[mapguide-users] postgis connection properties EMPTY!!!!!
Jim O'Leary
joleary.public at gmail.com
Wed Oct 17 14:16:12 EDT 2007
This is also true for the Autodesk.Raster.3.0 and King.Oracle.0.1.1
providers. DependencyWalker shows missing DLLS, but also gives cryptic
messages like:
Error: At least one module has an unresolved import due to a missing export
function in an implicitly dependent module.
Warning: At least one delay-load dependency module was not found.
Warning: At least one module has an unresolved import due to a missing
export function in a delay-load dependent module.
...which are not easily resolved by tossing DLLS here and there. Is there a
more comprensive fix for these problems in the works?
Thanks.
dorra2007 wrote:
> Problem resolved:
> there is DLL's missing: comerr.dll, krb5.dll,
> libintl-2.dll,visnint.dll,msvcp80.dll, to be copied in the FDO folder
> msjava.dll, libeay32.dll and ssleay32.dll....to be copied in the system32
> folder
> Kenneth, GEOGRAF A/S wrote:
>> The problem is that the PostGIS FDO Provider (as well as the other
>> providers) depend on certain Dll's being avalible.
>> I recommend using dependency walker to open the Dll, and view it
>> dependencies. It will highlight missing dll dependencies.
>> http://www.dependencywalker.com
>> Regards, Kenneth, GEOGRAF A/S
>> dorra2007 skrev:
>>> I have tried this steps. I have successfully connected to postgis with
>>> windows XP home. Now I am using WinLSD and i wanted to redo exactly the
>>> same
>>> steps, but I failed. I have always the 4 fields empty, no data to enter
>>> and
>>> of course, can't establish connection to postgis.
>>> Does the problem come from the operating system I use?
>>> macieksk wrote:
>>>> Try this steps.
>>>> 1. Install MG 1.2 Stable version
>>>> 2. Install Postgres 8.2.xx (), after that instal postgis extension.
>>>> 3. Download PostgGIS provider
>>>> 4. change provider.xml file in
>>>> C:\Program Files\MapGuideOpenSource\Server\Bin\FDO
>>>> (add this
>>>> <FeatureProvider>
>>>> <Name>OSGeo.PostGIS.3.2</Name>
>>>> <DisplayName>OSGeo FDO Provider for PostGIS</DisplayName>
>>>> <Description>FDO Provider for PostGIS</Description>
>>>> <IsManaged>False</IsManaged>
>>>> <Version>3.2.0.0</Version>
>>>> <FeatureDataObjectsVersion>3.2.0.0</FeatureDataObjectsVersion>
>>>> <LibraryPath>PostGISProvider.dll</LibraryPath>
>>>> </FeatureProvider>
>>>> 5. restart serwer.
>>>> 6. open Mg Studio->create new data connection->(in this place ypu
>>>> should
>>>> have Postgis provider) -> if all is ok you should have 4 fields to
>>>> enter
>>>> connection string.
>>>> dorra labidi pisze:
>>>>> Hi every body;
>>>>> I have reinstalled mapguide OS, web Studio and postgresql/postgis on
>>>>> my
>>>>> computer. I have also copied the postgisfdo provider DLL's and
>>>>> modified
>>>>> the providers.xml file. Finally I have copied the postgis bin folder
>>>>> to
>>>>> the bin folder of mapguide server OS.
>>>>> When I clic on "configure data connection", I find the postgis
>>>>> porvider
>>>>> in the list of providers.
>>>>> *The problem is that the "connection properties" fields are empty*:
>>>>> There is no username field nor password, schema and source field.
>>>>> The error message is :
>>>>> /An exception occurred in FDO component.
>>>>> Unable to load the FDO Provider: /
>>>>> Has anyone encountred this problem?
>>>>> Thank you very much for your help.
>>>> Maciej Skórczewski
>>>> PROCAD SA
>>>> Autodesk Authorized Value Added Reseller
>>>> www.procad.pl
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/postgis-connection-properties-EMPTY%21%21%21%21%21-tf4514993s16610.html#a13259692
