[mapguide-users] postgis connection properties EMPTY!!!!!
Jason Birch
Jason.Birch at nanaimo.ca
Wed Oct 17 14:32:09 EDT 2007
Jim,
What version of MapGuide are you trying to use these providers with? They're both fairly ancient, and likely are referencing DLLs that have since been updated.
King.Oracle is now at version 0.7.3 and has releases available for FDO 3.1, 3.2 (MGOS 1.1), and 3.2.2 (MGOS 1.2). For this provider, it's possible that you don't have the correct version of the Oracle client installed.
I have no ideas for Autodesk.Raster, and I'm surprised that you have 3.0. Wasn't 3.1 the version that shipped with MGE 2007?
Jason
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jim O'Leary
Sent: Wednesday, October 17, 2007 11:16
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] postgis connection properties EMPTY!!!!!
This is also true for the Autodesk.Raster.3.0 and King.Oracle.0.1.1 providers. DependencyWalker shows missing DLLS, but also gives cryptic messages like:
Error: At least one module has an unresolved import due to a missing export function in an implicitly dependent module.
Warning: At least one delay-load dependency module was not found.
Warning: At least one module has an unresolved import due to a missing export function in a delay-load dependent module.
...which are not easily resolved by tossing DLLS here and there. Is there a more comprensive fix for these problems in the works?
Thanks.
dorra2007 wrote:
> Problem resolved:
> there is DLL's missing: comerr.dll, krb5.dll,
> libintl-2.dll,visnint.dll,msvcp80.dll, to be copied in the FDO folder
> msjava.dll, libeay32.dll and ssleay32.dll....to be copied in the
> system32 folder
> Kenneth, GEOGRAF A/S wrote:
>> The problem is that the PostGIS FDO Provider (as well as the other
>> providers) depend on certain Dll's being avalible.
>> I recommend using dependency walker to open the Dll, and view it
>> dependencies. It will highlight missing dll dependencies.
>> http://www.dependencywalker.com
>> Regards, Kenneth, GEOGRAF A/S
>> dorra2007 skrev:
>>> I have tried this steps. I have successfully connected to postgis
>>> with windows XP home. Now I am using WinLSD and i wanted to redo
>>> exactly the same steps, but I failed. I have always the 4 fields
>>> empty, no data to enter and of course, can't establish connection to
>>> postgis.
>>> Does the problem come from the operating system I use?
>>> macieksk wrote:
>>>> Try this steps.
>>>> 1. Install MG 1.2 Stable version
>>>> 2. Install Postgres 8.2.xx (), after that instal postgis extension.
>>>> 3. Download PostgGIS provider
>>>> 4. change provider.xml file in
>>>> C:\Program Files\MapGuideOpenSource\Server\Bin\FDO
>>>> (add this
>>>> <FeatureProvider>
>>>> <Name>OSGeo.PostGIS.3.2</Name>
>>>> <DisplayName>OSGeo FDO Provider for PostGIS</DisplayName>
>>>> <Description>FDO Provider for PostGIS</Description>
>>>> <IsManaged>False</IsManaged>
>>>> <Version>3.2.0.0</Version>
>>>> <FeatureDataObjectsVersion>3.2.0.0</FeatureDataObjectsVersion>
>>>> <LibraryPath>PostGISProvider.dll</LibraryPath>
>>>> </FeatureProvider>
>>>> 5. restart serwer.
>>>> 6. open Mg Studio->create new data connection->(in this place ypu
>>>> should have Postgis provider) -> if all is ok you should have 4
>>>> fields to enter connection string.
>>>> dorra labidi pisze:
>>>>> Hi every body;
>>>>> I have reinstalled mapguide OS, web Studio and postgresql/postgis
>>>>> on my computer. I have also copied the postgisfdo provider DLL's
>>>>> and modified the providers.xml file. Finally I have copied the
>>>>> postgis bin folder to the bin folder of mapguide server OS.
>>>>> When I clic on "configure data connection", I find the postgis
>>>>> porvider in the list of providers.
>>>>> *The problem is that the "connection properties" fields are empty*:
>>>>> There is no username field nor password, schema and source field.
>>>>> The error message is :
>>>>> /An exception occurred in FDO component.
>>>>> Unable to load the FDO Provider: / // Has anyone encountred this
>>>>> problem?
>>>>> Thank you very much for your help.
>>>> Maciej Skórczewski
>>>> PROCAD SA
>>>> Autodesk Authorized Value Added Reseller www.procad.pl
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/postgis-connection-properties-EMPTY%21%21%21%21%21-tf4514993s16610.html#a13259692
