[mapguide-users] Edit digitizing style
Rui Vilanova
rui.vilanova at gismedia.pt
Fri Oct 26 04:49:35 EDT 2007
Thanks Andy, it works.
Anyway, I found a bug. When the map height is bigger then the width, I can only digitize a polygon or a linestring in the top of the map.
If you apply a border to the feedback class in the ajaxmappane.templ, you can see it when you're digitizing. It doesn't allow to digitize out of that border.
Kind regards,
Rui
-----Mensagem original-----
De: mapguide-users-bounces at lists.osgeo.org
[mailto:mapguide-users-bounces at lists.osgeo.org]Em nome de Andy Morsell
Enviada: quinta-feira, 25 de Outubro de 2007 18:05
Para: 'MapGuide Users Mail List'
Assunto: RE: [mapguide-users] Edit digitizing style
Take a look at the ajaxmappane.templ file. Specifically, the DigitizePoint,
DigitizePolygon, and so on functions. Each one calls StartDigitizing which
then calls a digitizer from the digitize.js script file. The digitizer has
a parameter that is color (fbColor). It is the 6th parameter (the default
is black, #000000). Change that parameter to whatever web color you want
and it should work. Keep in mind that making this change will be a global
site change......
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of ruivilanova
Sent: Thursday, October 25, 2007 8:05 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Edit digitizing style
does anyone know if it's possible to edit the digitizing line style? I mean,
I want a red line instead of a black one.
Thanks in advance,
Rui
View this message in context:
http://www.nabble.com/Edit-digitizing-style-tf4691477s16610.html#a13408727
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
