[mapguide-users] Major Feature Join Problems
Jackie Ng jackie.ng at aecsystems.com.au
Tue Oct 30 00:25:35 EDT 2007
Hi Jason,
I'm in the process of preparing this new problem package, which I'll attach
to that ticket.
- Jackie
JasonBirch wrote:
> Hi Jackie,
> I closed that under the assumption that it was a problem with the SHP->SDF
> translation in Studio.  If you are seeing the problem under different
> circumstances, please re-open the ticket.  If you have an additional
> package that you could create to show the problem with this new data, as
> well as detailed (so a robot could understand) steps to reproduce, then
> that would be good.
> Also, if you want to provide me with a link off-list to download the
> original SHP files, I'd be happy to run them through FME, test for invalid
> features, etc..., and give them back to you as SDF just in case there's a
> problem with Map as well.
> Jason
> ________________________________
> From: Jackie Ng
> Subject: [mapguide-users] Major Feature Join Problems
> I wasn't fussed about the ticket being filed invalid, because I was able
> to
> workaround the problem by exporting straight to SDF, instead of exporting
> to
> SHP -> convert to SDF at the load procedure.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Major-Feature-Join-Problems-tf4716245s16610.html#a13482294
