[mapguide-users] Windows-based application
Jackie Ng
jackie.ng at aecsystems.com.au
Tue Oct 30 02:12:37 EDT 2007
You can utilise the .net API in a windows client application only if the host
which the client application will run, can reach the mapguide site server,
because the mapguide API is meant to be used on a server/web "tier".
If this is not what you are after, then unfortunately you cannot use the
.net API.
- Jackie
A H wrote:
> can i use MapGuide Open Source on ASP.NET C# to develop a windows-based
> client application? is there any example for this?
View this message in context: http://www.nabble.com/Windows-based-application-tf4715661s16610.html#a13483031
