[mapguide-users] Windows-based application
Kenneth, GEOGRAF A/S
ks at geograf.dk
Tue Oct 30 03:31:32 EDT 2007
On workaround would be to open the correct port in the firewall, but
that will probably open up all sorts of security hazards.
Another solution is to create a .Net wrapper for the HTTP interface of
the mapguide server.
I have built such a wrapper, and licensed it under LGPL.
It is not complete, but mail me off-list if you want a development copy
to build on.
Regards, Kenneth, GEOGRAF A/S
Jackie Ng skrev:
> You can utilise the .net API in a windows client application only if the host
> which the client application will run, can reach the mapguide site server,
> because the mapguide API is meant to be used on a server/web "tier".
> If this is not what you are after, then unfortunately you cannot use the
> .net API.
> - Jackie
> A H wrote:
>> can i use MapGuide Open Source on ASP.NET C# to develop a windows-based
>> client application? is there any example for this?
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071030/50e0f684/attachment.html
