[mapguide-users] Fluctuating Cursor Accuracy
Jackie Ng
jackie.ng at aecsystems.com.au
Tue Oct 30 18:54:27 EDT 2007
Is there whitespace at the top of your AJAX viewer? (below the toolbar)
- Jackie
joecm wrote:
> When using an AJAX map, cursor is not always aligned properly.
> For example, if I go to select a polygon, sometimes the polygon on the
> tail or middle of the cursor is selected, instead of the point of the
> cursor. It seems to vary each time I load the page, sometimes it is
> correct, other times it is not. This is very confusing to users who
> think they are clicking on one polygon and actually clicking on another.
> Has anyone else encountered this problem, or even better, found a fix?
> Thanks
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Best-method-to-use-dwg-files-tf4719897s16610.html#a13499525
