[mapguide-users] Fluctuating Cursor Accuracy
IT-Joe Marvin
JMarvin at redwoodcity.org
Tue Oct 30 19:26:35 EDT 2007
Jackie,
After doing a bit more testing, the white space is the exact size of the
offset of the cursor. The question is then, how can I prevent, or
detect this white space?
-joe
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of IT-Joe
Marvin
Sent: Tuesday, October 30, 2007 4:00 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Fluctuating Cursor Accuracy
Yes there is.
-joe
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Tuesday, October 30, 2007 3:54 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Fluctuating Cursor Accuracy
Is there whitespace at the top of your AJAX viewer? (below the toolbar)
- Jackie
joecm wrote:
> When using an AJAX map, cursor is not always aligned properly.
> For example, if I go to select a polygon, sometimes the polygon on
the
> tail or middle of the cursor is selected, instead of the point of the
> cursor. It seems to vary each time I load the page, sometimes it is
> correct, other times it is not. This is very confusing to users who
> think they are clicking on one polygon and actually clicking on
another.
> Has anyone else encountered this problem, or even better, found a fix?
> Thanks
> mapguide-users mailing list
View this message in context:
http://www.nabble.com/Best-method-to-use-dwg-files-tf4719897s16610.html#
a13499525
