[mapguide-users] Fluctuating Cursor Accuracy
Jackie Ng
jackie.ng at aecsystems.com.au
Tue Oct 30 19:43:54 EDT 2007
We get this problem sometimes, the whitespace causes displacement of the map,
throwing off the accuracy of the selection tools.
If you resize any part of the ajax viewer that would cause a resize of the
map pane, the whitespace will disappear and your selection accuracy should
be restored.
- Jackie
joecm wrote:
> Yes there is.
> -joe
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> Sent: Tuesday, October 30, 2007 3:54 PM
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] Fluctuating Cursor Accuracy
> Is there whitespace at the top of your AJAX viewer? (below the toolbar)
> - Jackie
> joecm wrote:
>> When using an AJAX map, cursor is not always aligned properly.
>> For example, if I go to select a polygon, sometimes the polygon on
> the
>> tail or middle of the cursor is selected, instead of the point of the
>> cursor. It seems to vary each time I load the page, sometimes it is
>> correct, other times it is not. This is very confusing to users who
>> think they are clicking on one polygon and actually clicking on
> another.
>> Has anyone else encountered this problem, or even better, found a fix?
>> Thanks
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/Best-method-to-use-dwg-files-tf4719897s16610.html#
> a13499525
> Sent from the MapGuide Users mailing list archive at Nabble.com.
View this message in context: http://www.nabble.com/Best-method-to-use-dwg-files-tf4719897s16610.html#a13500077
