[mapguide-users] Remove layer C#
Alex Fordyce
afordyce at ix.netcom.com
Thu Sep 6 12:14:30 EDT 2007
Worked perfectly. Thank you very much. Now my application allows the user to
create multiple queries on the same "query layer". Rather than creating a
new layer for each query.
Thanks again.
Jackie Ng wrote:
> Remove() is expecting a MgLayerBase object, you are passing in a string.
> Hence the compilation error.
> Maybe try something like this instead:
> MgMap map = new MgMap(siteConnection);
> map.Open(mgMapName);
> MgLayerCollection layerCol = map.GetLayers();
> string layerName = "myLayer";
> MgLayer layerToRemove = null;
> foreach(MgLayer layer in layerCol)
> if(layer.Name == layerName)
> layerToRemove = layer;
> break;
> if(layerToRemove != null)
> layerCol.Remove(layerToRemove);
> - Jackie.
> Alex Fordyce wrote:
>> I'm to see if a layer exists and remove it if it exists. The layer would
>> have been saved as a temporary resource. Here is the code.
>> // get the map
>> if(layerCol.Contains("myLayer"))
>> layerCol.Remove("myLayer");
>> .... Add myLayer code here .....
>> I get the following error whether or not the layer exists:
>> Compiler Error Message: CS1502: The best overloaded method match for
>> 'OSGeo.MapGuide.MgLayerCollection.Remove(OSGeo.MapGuide.MgLayerBase)' has
>> some invalid arguments
>> Source Error:
>> Line 42: if(layerCol.Contains("myLayer"))
>> Line 43: {
>> Line 44: layerCol.Remove("myLayer");
>> Line 45: }
>> Line 46:
>> Anyone have any suggestions?
>> Thanks in advance.
>> alex
View this message in context: http://www.nabble.com/Remove-layer-C--tf4388428s16610.html#a12526003
