[mapguide-users] Remove layer C#
Jackie Ng jackie.ng at aecsystems.com.au
Wed Sep 5 20:26:41 EDT 2007
Remove() is expecting a MgLayerBase object, you are passing in a string.
Hence the compilation error.
Maybe try something like this instead:
MgMap map = new MgMap(siteConnection);
map.Open(mgMapName);
MgLayerCollection layerCol = map.GetLayers();
string layerName = "myLayer";
MgLayer layerToRemove = null;
foreach(MgLayer layer in layerCol)
      if(layer.Name == layerName)
            layerToRemove = layer;
            break;
if(layerToRemove != null)
      layerCol.Remove(layerToRemove);
- Jackie.
Alex Fordyce wrote:
> I'm to see if a layer exists and remove it if it exists. The layer would
> have been saved as a temporary resource. Here is the code.
> // get the map
> if(layerCol.Contains("myLayer"))
>      layerCol.Remove("myLayer");
> .... Add myLayer code here .....
> I get the following error whether or not the layer exists:
>  Compiler Error Message: CS1502: The best overloaded method match for
> 'OSGeo.MapGuide.MgLayerCollection.Remove(OSGeo.MapGuide.MgLayerBase)' has
> some invalid arguments
> Source Error:
> Line 42: 	if(layerCol.Contains("myLayer"))
> Line 43: 	{
> Line 44: 		layerCol.Remove("myLayer");
> Line 45: 	}
> Line 46:
> Anyone have any suggestions?
> Thanks in advance.
> alex
View this message in context: http://www.nabble.com/Remove-layer-C--tf4388428s16610.html#a12513568
