[mapguide-users] Linux install error
Ronnie Louie ronnie.louie at autodesk.com
Thu Sep 6 12:29:11 EDT 2007
Andre,
The following information should help you get past this.
http://trac.osgeo.org/mapguide/ticket/147
Ronnie
Sent: Thursday, September 06, 2007 3:35 AM
To: 'MapGuide Users Mail List'
Subject: [mapguide-users] Linux install error
I am trying to install MGOS 1.2 on the following:
Intel Duo Core 1gb Ram
Fedore 6,
GCC 4.1.1.
Java 1.4
Libjpeg - downloaded and installed
<Source path>=/software/MGOS/
Step - Build and Install Apache and Php - completed successfully and
Apache works on port 8008.
Step - Build and Install FDO - completed successfully
Step - Build OEM (command ./build_oem.sh) gives the following error at
the end "
Core.cpp: In function 'int DWFCore::AtomicIncrement(volatile int*)':
Core.cpp:101: error: 'atomic_t' was not declared in this scope
Core.cpp:101: error: expected `;' before 'tValue'
Core.cpp:102: error: 'tValue' was not declared in this scope
Core.cpp:102: error: 'atomic_set' was not declared in this scope
Core.cpp:107: error: invalid lvalue in asm statement
Core.cpp:109: error: 'atomic_read' was not declared in this scope
Core.cpp:107: error: invalid lvalue in asm output 0
Core.cpp:107: error: memory input 1 is not directly addressable
Core.cpp: In function 'int DWFCore::AtomicDecrement(volatile int*)':
Core.cpp:118: error: 'atomic_t' was not declared in this scope
Core.cpp:118: error: expected `;' before 'tValue'
Core.cpp:119: error: 'tValue' was not declared in this scope
Core.cpp:119: error: 'atomic_set' was not declared in this scope
Core.cpp:124: error: invalid lvalue in asm statement
Core.cpp:126: error: 'atomic_read' was not declared in this scope
Core.cpp:124: error: invalid lvalue in asm output 0
Core.cpp:124: error: memory input 1 is not directly addressable
make[2]: *** [Core.lo] Error 1
make[2]: Leaving directory
`/software/MGOS/mapguide-1.2.0/Oem/DWFTK7.1/develop/global/src/dwfcore/x
86'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory
`/software/MGOS/mapguide-1.2.0/Oem/DWFTK7.1/develop/global/src/dwfcore'
make: *** [all] Error 2
DWFCORE 1.0: Error build failed (0).................
[root at localhost mapguide-1.2.0]#
Any help will be appreciated!
Kind Regards
Andre
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070906/0a48fb63/attachment.html
