[mapguide-users] SDF & SQL Server 2005 Joined Feature Source
Ronnie Louie
ronnie.louie at autodesk.com
Fri Sep 7 12:22:28 EDT 2007
Hi Max,
The exception message resulting from line 403 of
mapguidecommon/Services/ProxyGwsFeatureReader.cpp tells me that the
filter value is expecting an integer type, and you have actually passed
it a double. Try modifying your script so that the line that reads
$n=$name+0.0 is changed to $n=$name.
Ronnie
Sent: Thursday, September 06, 2007 9:18 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] SDF & SQL Server 2005 Joined Feature
Source
Hi Ronnie,
Thanks for your kind reply,Actually first i tried to work
with SQL Server 2005 and storing Geometry data using Map3D2008 and i
manage to create datastore and edit,delete update etc from Map3D 2008
then i tried to use it for the web and tried to theme and modify using
the ADSK Mapguide studio 2008 but here the problem start arising and i
unable to get the properties and other things in the mapguide studio
although i able to manage connection ang get new feature classes etc but
unable to view and when i try to change some themeing condition it use
to give error that some table doesn not exists although i can easily
work with map3D 2008 with the same table,so then i tried to work with
SDF and joined the SDF file with SQL server2005 Views and i tried to
query but as you told that it will filter only on primary source of join
so i tried to set filter on the primary source of the joined feature
source,
$name = trim($_GET['sDeed']);
if (strlen($name) > 0 )
$n=$name+0.0;
echo gettype($n);---------------------->Double
$filter="ID=".$n;
$featureResId = new
MgResourceIdentifier("Library://ABC/Data/Estates.FeatureSource");
$queryOptions = new MgFeatureQueryOptions();
$queryOptions->SetFilter($filter);
This use to give the following error in the joined feature source with
filter on primary source-
Double
ID=1The Property Type is invalid.The Property Type is invalid. Exception
occurred in method MgProxyGwsFeatureReader.GetProperty at line 403 in
file
c:\build_bond_area\bond_nightly\build_41.3\ent\os\common\mapguidecommon\
but when i use the same filter on the SDF File(not Joined) it use to
give me the result ,so can you tell me what i am missing or doing wrong
and how can i proceed with working SQL Server 2005 and Autodesk MapGuide
Studio 2008.
Thanks
Max
Ronnie Louie <ronnie.louie at autodesk.com> wrote:
Hi Max,
When you have join of SDF to SQL Server feature source, you can
only define a filter for the fields from the primary source of the join
(i.e. the properties in the SDF). It is not currently possible to setup
a filter for the secondary feature source of a join (i.e. the SQL Server
datasource properties). Depending on what you a trying to achieve, you
may be able to get similar desired result by setting up an appropriate
theme based on the properties from the secondary feature source.
Ronnie
Sent: Thursday, September 06, 2007 3:27 AM
Subject: [mapguide-users] SDF & SQL Server 2005 Joined Feature
Source
Hi All,
I tried to join the SDF faeture source spatial data
with the SQL Server 2005 Views(non spatial data) ,I manage to get the
new joined feature source and get the attributes in the property pane
but i stuck in the Search criteria and when i tried to search the
joined feature class using the filter like -
$filter ="LU_STATUS = '" . $status ."'"." and " . "PD_GROUP=
'".$group."'"." and " . "SHAREHOLDE= '".$share."'"." or " . "PROMOTION=
'".$plan."'";
I unable to get any values and it use to give no search
found.Can anybody help me regarding this issue and where i can get some
detail for working with SQL commands on the feature source ,i tried in
the mapagent some basic sql commands but it use to give error and i
cannot find the way to go with them.
Thanks
Max
_____
Yahoo! oneSearch: Finally, mobile search that gives answers
<http://us.rd.yahoo.com/evt=48252/*http:/mobile.yahoo.com/mobileweb/ones
earch?refer=1ONXIC> , not web links.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
_____
Moody friends. Drama queens. Your life? Nope! - their life, your story.
Play Sims Stories at Yahoo! Games.
<http://us.rd.yahoo.com/evt=48224/*http:/sims.yahoo.com/>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070907/69fe7e46/attachment.html
