[mapguide-users] How to prepare the unmanaged feature source?
Kenneth, GEOGRAF A/S
ks at geograf.dk
Sun Sep 9 07:21:23 EDT 2007
Afaik, there is no template.
To use the "unmanaged feature source" feature, you must have a server of
build 1.2 or greater (Enterprise 2008 is roughly 1.2 Beta2).
Sencondly the unmanaged feature is avalible but not displayed in Studio
2007.
You will have to upgrade if you want it displayed in Studio.
You can setup an unmanaged directory, using the "Site Administrator"
(there is a menu for opening the site administrator in Studio).
Once the folder is setup, you can use it from within Studio 2008.
If you use Studio 2007, you must manually edit the FeatureSource xml
file, and change the path to something like:
%MG_DATA_PATH_ALIAS[name of alias]%/name of datafile.sdf
You will probably have to restart both the server and studio if you add
or remove an alias.
If you don't want the alias option, but just reference data outside of
the repository, you can manually edit the FeatureSource xml, to point at
the correct data.
Regards, Kenneth, GEOGRAF A/S
Carl skrev:
> Where I can find the template of unmanaged featuresource, or layer?
