[mapguide-users] How to prepare the unmanaged feature source?
Carl
carlshe at 163.com
Mon Sep 10 00:25:06 EDT 2007
Can somebody share a XML example of an unmanaged feature source definition?
Kenneth, GEOGRAF A/S wrote:
> Afaik, there is no template.
> To use the "unmanaged feature source" feature, you must have a server of
> build 1.2 or greater (Enterprise 2008 is roughly 1.2 Beta2).
> Sencondly the unmanaged feature is avalible but not displayed in Studio
> 2007.
> You will have to upgrade if you want it displayed in Studio.
> You can setup an unmanaged directory, using the "Site Administrator"
> (there is a menu for opening the site administrator in Studio).
> Once the folder is setup, you can use it from within Studio 2008.
> If you use Studio 2007, you must manually edit the FeatureSource xml
> file, and change the path to something like:
> %MG_DATA_PATH_ALIAS[name of alias]%/name of datafile.sdf
> You will probably have to restart both the server and studio if you add
> or remove an alias.
> If you don't want the alias option, but just reference data outside of
> the repository, you can manually edit the FeatureSource xml, to point at
> the correct data.
> Regards, Kenneth, GEOGRAF A/S
> Carl skrev:
>> Where I can find the template of unmanaged featuresource, or layer?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/How-to-prepare-the-unmanaged-feature-source--tf4408812s16610.html#a12586491
