[mapguide-users] RE: Postgis/mapguide
Intengu Technologies
sindile.bidla at gmail.com
Thu Sep 13 08:07:31 EDT 2007
> 1. Create a datasource
How does one create a datasource using WebStudio or can some please post a
working example of a datasource.
On 13/09/2007, Kenneth, GEOGRAF A/S <ks at geograf.dk> wrote:
> If you are able to connect to the datasource, there should be no problem
> displaying it.
> These are the steps to follow:
> 2. Point it to the PostGIS database
> 3. Click "Test connection"
> 4. When it works, save the datasource.
> 5. Create a new layer
> 6. Point the layer to the datasource.
> 7. Select the table to use.
> 8. Style the point, line and area to your pleasing.
> 9. Save the layer.
> 10. Create a mapdefinition.
> 11. Select the correct projection for the data.
> 12. Add the layer to the map, make sure you have "Layer is initially
> visble in the map" checked.
> 13. Save the map.
> 14. Create a new WebLayout.
> 15. Select the map.
> 16. Save the WebLayout.
> After item 7, you should be able to preview your data, using the "Preview"
> feature.
> Item 8 is where you could set up filters and the like.
> You can repeat item 12, if you have many layers.
> If the above does not help, try to explain where it goes wrong.
> Regards, Kenneth, GEOGRAF A/S
> dorra labidi skrev:
> Thank you for your responses;
> I have successfully installed the fdoPostgis provider and connected
> mapguide studio to it.
> The problem is how could I display the data contained in the postgis
> tables an make some requests in them (inserting data, filters...etc).
> In other words, I want to access the postgis data and display them...
> Ne gardez plus qu'une seule adresse mail ! Copiez vos mails<http://www.trueswitch.com/yahoo-fr/>vers Yahoo! Mail
> mapguide-users mailing list
> mapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users
Sindile Bidla
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070913/27bcb208/attachment.html
