[mapguide-users] MGOS 1.2 mgserver.exe
Frank Warmerdam
warmerdam at pobox.com
Thu Sep 13 09:14:58 EDT 2007
kym wrote:
> Hi
> has anyone else had problems with the mgserver.exe service not dieing in
> MGOS v1.2 and then not being able to stop and start the service without
> restarting the machine, this is on windows 2003. This seems to occur when it
> is rendering raster(ecw & tiffs) base layers to the tile cache. It also
> sometimes generates blank(white) tiles where there should be the tile raster
> images.
Kym,
I wonder if this occurs if you *only* use TIFFs with no ECWs?
I have observed in some situations the ECW library does a poor job cleaning
up it's threads and this can make applications hang at exit. I wonder if
this might be the issue.
If we can isolate this issue to ECWs then it might turn out to be an artifact
of how the ECW SDK is being built from source for use by MapGuide. If so, we
could look into building against an ECW SDK actually built by ERMapper which
presumably have such issues resolved properly.
If you can isolate the issue, I'd encourage you to create a Trac ticket in the
*FDO* Trac (http://trac.osgeo.org/fdo) assigned to me (userid: warmerdam).
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
