[mapguide-users] MGOS 1.2 mgserver.exe
Kym Ralph Kym.Ralph at kbr.com
Fri Sep 14 03:46:27 EDT 2007
Hi Frank
I convert all the ecw files to tiffs using the fwtools and I don't have
the problem with the mgserver.exe becoming unresponsive. The real
problem seems to occur when mapguide is accessing a group of 123 ecw
files in one directory, the other directories of only 5-10 ecw files
work fine. I created all the image datasets using Jason's
rasterconfig.php tool. Is there any way to capture the ecw errors as
running mgserver in debug mode doesn't return any errors, so I can feed
it into the FDO trac ticket??
Thanks
Kym
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Frank
Warmerdam
Sent: Thursday, 13 September 2007 10:45 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] MGOS 1.2 mgserver.exe
kym wrote:
> Hi
> has anyone else had problems with the mgserver.exe service not dieing
in
> MGOS v1.2 and then not being able to stop and start the service
without
> restarting the machine, this is on windows 2003. This seems to occur
when it
> is rendering raster(ecw & tiffs) base layers to the tile cache. It
also
> sometimes generates blank(white) tiles where there should be the tile
raster
> images.
Kym,
I wonder if this occurs if you *only* use TIFFs with no ECWs?
I have observed in some situations the ECW library does a poor job
cleaning
up it's threads and this can make applications hang at exit.  I wonder
if
this might be the issue.
If we can isolate this issue to ECWs then it might turn out to be an
artifact
of how the ECW SDK is being built from source for use by MapGuide.  If
so, we
could look into building against an ECW SDK actually built by ERMapper
which
presumably have such issues resolved properly.
If you can isolate the issue, I'd encourage you to create a Trac ticket
in the
*FDO* Trac (http://trac.osgeo.org/fdo) assigned to me (userid:
warmerdam).
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush    | President OSGeo,
http://osgeo.org
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
This e-mail, including any attached files, may contain confidential and privileged information for the sole use of the intended recipient.  Any review, use, distribution, or disclosure by others is strictly prohibited.  If you are not the intended recipient (or authorized to receive information for the intended recipient), please contact the sender by reply e-mail and delete all copies of this message.
