[mapguide-users] MGE: Composite line styles with EndCaps and Roads infrastructure
Maksim Sestic max at geoinova.com
Sat Sep 15 08:00:45 EDT 2007
Dear all,
I'm hitting a problem while displaying Roads layer using composite line
style. Road line style should consist of a 3pts thick yellow "fill" bordered
with 4 pts thick black lines from both sides. Roads are kept in a datastore
as (segmented) LineStrings. The trouble is - composite line styles generate
EndCaps automatically on each LineString's start/end.
This is how it's construed inside MapGuide Studio 2008:
http://www.nabble.com/file/p12689297/Image_MGS_Dialog.jpg
Image (A) displays how it should look like:
http://www.nabble.com/file/p12689297/Image_A_Correct.jpg
Image (B) displays how it looks like when using described MGS 2008 composite
line styles:
http://www.nabble.com/file/p12689297/Image_B_Incorrect.jpg
Is there any solution to it? I'm using MGE 2008, MG Studio 2008, AJAX Viewer
and FDO 3.2 enabled MS SQL Server.
With kindest regards,
Maksim Sestic
View this message in context: http://www.nabble.com/MGE%3A-Composite-line-styles-with-EndCaps-and-Roads-infrastructure-tf4447383s16610.html#a12689297
