[mapguide-users] [fussion] Will Fusion meet OpenLayers providerstyle? ( multi-provider client)
Paul Spencer pagameba at gmail.com
Tue Sep 18 08:58:37 EDT 2007
Fusion, when it is actually integrated into MapGuide OS, will use
OpenLayers for managing the map component (in fact we have done this
in the development version so it will be in the next update).
The initial integration will not expose an API that will allow you to
work directly with OpenLayers to add custom layer types simply
because we are on a very tight schedule - some custom hacking should
enable you to do this, but it won't be supported.  It is planned to
expand the API to include functions for adding and removing
OpenLayers layers to the map in the client, meaning you could set up
a mapguide application and add WMS layers (for instance) on the
client side without having to modify your MapDefinition.
Cheers
Paul
On 15-Sep-07, at 1:08 AM, Brad Nesom wrote:
> Now this is what I have been thinking! If it were so then it seems
> to me that fdo providers would not be required for esri pgdb and
> many other data types.
> Brad
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
> bounces at lists.osgeo.org] On Behalf Of Eduardo Patto Kanegae
> Sent: Friday, September 14, 2007 7:37 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] [fussion] Will Fusion meet OpenLayers
> Hi,
> I´m testing Fusion technology and found that DM guys did it again!
> Congratulations, it´s an amazing product.
> My question is: will Fusion be like OpenLayers, I mean: a multi
> provider data access tool?
> Currently Fusion supports MapServer, WMS and MapGuide resources.
> But, I´d like to know if is possible to include more protocols to
> its resources reading capabilites ( eg.: GeoRSS, KML, ArcXML,
> ArcGIS Server, etc.)?
> best regards.
> mapguide-users mailing list
|Paul Spencer                          pspencer at dmsolutions.ca    |
|Chief Technology Officer                                         |
|DM Solutions Group Inc                http://www.dmsolutions.ca/ |
