[mapguide-users] .NET connection issue
Jackie Ng
jackie.ng at aecsystems.com.au
Mon Sep 17 19:14:20 EDT 2007
Are you using a pre 1.2 webconfig.ini? Because the 1.2 webconfig.ini has new
options which the 1.2 API requires.
- Jackie
ZoffoMan wrote:
> mgos 1.2 on windows sever 2003 using .net 2.0
> verified dotnetviewersample is working fine.
> I wrote a "web app" not a "web site"
> This has worked perfect for over 10 months using mapguide 1.0, 1.1
> I upgraded to 1.2 on a clean machine after recompiling, etc with new dlls.
> Now when I connect to my Default.aspx I get:
> Cannot establish connection.
> - MgSite.Open line 105 file
> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\common\mapguidecommon\Services/Site.cpp
> - MgSite.Authenticate line 1270 file
> - MgServerConnection.Open line 98 file
> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\common\mapguidecommon\Services/ServerConnection.cpp
> I noticed the mapagent.exe and php-cgi.exe process were not started (4
> start, 4 max in registry)
> However, if I restart the www service and then open the dotnetviewersample
> - the dotnetviewersample works fine. I then notice that mapagent.exe and
> php-cgi.exe are there (4 each)
> I can then use my web project with no errors!
> It is like the MapGuideApi.MgInitializeWebTier(configPath) is not working.
> My webconfig.ini is in the webapp directory not the mapguide directory -
> but it finds the location, etc. They are identical of course.
> Any thoughts?
View this message in context: http://www.nabble.com/.NET-connection-issue-tf4467427s16610.html#a12746988
