[mapguide-users] .NET connection issue
ZoffoMan
zoffo at adelphia.net
Mon Sep 17 23:48:27 EDT 2007
Yes! That was the problem. They have different ports and everything. It's
weird how using dotnetviewersample first would init properly and allow you
to use a "bad" config.
Thanks.
Jackie Ng wrote:
> Are you using a pre 1.2 webconfig.ini? Because the 1.2 webconfig.ini has
> new options which the 1.2 API requires.
> - Jackie
> ZoffoMan wrote:
>> mgos 1.2 on windows sever 2003 using .net 2.0
>> verified dotnetviewersample is working fine.
>> I wrote a "web app" not a "web site"
>> This has worked perfect for over 10 months using mapguide 1.0, 1.1
>> I upgraded to 1.2 on a clean machine after recompiling, etc with new
>> dlls.
>> Now when I connect to my Default.aspx I get:
>> Cannot establish connection.
>> - MgSite.Open line 105 file
>> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\common\mapguidecommon\Services/Site.cpp
>> - MgSite.Authenticate line 1270 file
>> - MgServerConnection.Open line 98 file
>> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\common\mapguidecommon\Services/ServerConnection.cpp
>> I noticed the mapagent.exe and php-cgi.exe process were not started (4
>> start, 4 max in registry)
>> However, if I restart the www service and then open the
>> dotnetviewersample - the dotnetviewersample works fine. I then notice
>> that mapagent.exe and php-cgi.exe are there (4 each)
>> I can then use my web project with no errors!
>> It is like the MapGuideApi.MgInitializeWebTier(configPath) is not
>> working.
>> My webconfig.ini is in the webapp directory not the mapguide directory -
>> but it finds the location, etc. They are identical of course.
>> Any thoughts?
View this message in context: http://www.nabble.com/.NET-connection-issue-tf4467427s16610.html#a12749508
