[mapguide-users] MGOS 1.2.0 Filter On Joined Field
Rahul unicorn_admirer at yahoo.com
Mon Sep 17 23:45:30 EDT 2007
   I think i already asked these question many times and i stuck up with the join using SDF +SQL Server 2005(ODBC) and i unable to filter on the field from the joined table,for that i got answer from autodesk that filter will work only on primary source so still no solution for the filtering on the secondry source.Looking forward for some more info on this from others.
  cheers
  Max !!
Krunoslav <a_krunoslav at gmx.net> wrote:
James Card wrote:
> I just tested again on MGOS 1.2.0 and am still not able filter a layer on
> a field from a joined table (for example, the expression '"Join1ClassRoom"
> = TRUE' does not work). I was sure that we've discussed here before, and
> even thought that it had been fixed, but I just searched through Trac and
> did not find a ticket on this.
> Is this feature working working for others (which would indicate that I
> have simply misconfigured my filter definition)?
I don't know if this is same problem as mine (posted 20 mins ago), but it
seems so. So you are not alone on this.
View this message in context: http://www.nabble.com/MGOS-1.2.0-Filter-On-Joined-Field-tf4470070s16610.html#a12745898
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
Be a better Heartthrob. Get better relationship answers from someone who knows.
Yahoo! Answers - Check it out.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070917/98abeab2/attachment.html
