[mapguide-users] MGOS 1.2.0 Filter On Joined Field
Zac Spitzer
zac.spitzer at gmail.com
Tue Sep 18 00:19:25 EDT 2007
i previously logged a ticket here
http://trac.osgeo.org/mapguide/ticket/254 about layer filters
mapguide currently just fails silently on layer errors and the will
resubmit the query against the datasource without any criteria.. ugly
z
On 9/18/07, Rahul <unicorn_admirer at yahoo.com> wrote:
> Hi,
> I think i already asked these question many times and i stuck up with the
> join using SDF +SQL Server 2005(ODBC) and i unable to filter on the field
> from the joined table,for that i got answer from autodesk that filter will
> work only on primary source so still no solution for the filtering on the
> secondry source.Looking forward for some more info on this from others.
> cheers
> Max !!
> Krunoslav <a_krunoslav at gmx.net> wrote:
> James Card wrote:
> > I just tested again on MGOS 1.2.0 and am still not able filter a layer on
> > a field from a joined table (for example, the expression '"Join1ClassRoom"
> > = TRUE' does not work). I was sure that we've discussed here before, and
> > even thought that it had been fixed, but I just searched through Trac and
> > did not find a ticket on this.
> > Is this feature working working for others (which would indicate that I
> > have simply misconfigured my filter definition)?
> I don't know if this is same problem as mine (posted 20 mins ago), but it
> seems so. So you are not alone on this.
> http://www.nabble.com/MGOS-1.2.0-Filter-On-Joined-Field-tf4470070s16610.html#a12745898
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> ________________________________
> Be a better Heartthrob. Get better relationship answers from someone who
> knows.
> Yahoo! Answers - Check it out.
Zac Spitzer
http://zacster.blogspot.com/
+61 3 9018 5778 (voip via my pc)
+61 405 847 168 (aussie moible)
