[mapguide-users] MGOS 1.2.0 Filter On Joined Field
Jorge Rubio j.e.rubio at gmail.com
Wed Sep 19 12:01:54 EDT 2007
What are you trying to do?
Do you want filter data in Studio to set properties values to layers?
Do you want filter data by code -inside an application- to modify properties
values to layers?
If I need to filter data to set properties values (or define condition to
set themes) to layers based on a secondary source field, I use to create a
view in my database to set all the fields I need in a single table. I create
a DataSource Connection to my database and then I use the view as Feature
Class.
2007/9/17, James Card <James.Card at calcad.com>:
> I just tested again on MGOS 1.2.0 and am still not able filter a layer on
> a field from a joined table (for example, the expression '"Join1ClassRoom"
> = TRUE' does not work). I was sure that we've discussed here before, and
> even thought that it had been fixed, but I just searched through Trac and
> did not find a ticket on this.
> Is this feature working working for others (which would indicate that I
> have simply misconfigured my filter definition)?
> James Card
> 209-578-5580
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Lic. Jorge Rubio
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070919/108d9457/attachment.html
