[mapguide-users] 1.2 using .net 2.0 and VS2005 and web applicationproject
ZoffoMan zoffo at adelphia.net
Mon Sep 17 23:50:34 EDT 2007
5. make sure you use a mgos 1.2 webconfig.ini - If you use a 1.1 you can get
undesirable behavior ;)
FM-5 wrote:
> Yes, we have done that for a while now...
> You must make sure to:
> 1. Create your project as a web application
> 2. Make sure your web in IIS works with .NET 2.0
> 3. Move the MapGuide Dlls (MapGuideDotNetApi.dll,
> MapGuideUnmanagedApi.dll)
> to your new bin directory (copy local when adding references)
> 4. Move your webconfig.ini and set the correct parameters
> I hope that will help you.
> ----- Original Message -----
> From: "ZoffoMan" <zoffo at adelphia.net>
> To: <mapguide-users at lists.osgeo.org>
> Sent: Monday, September 17, 2007 4:09 PM
> Subject: [mapguide-users] 1.2 using .net 2.0 and VS2005 and web
> applicationproject
>> Has anyone had success connecting to mapguide via a web applicaiton
>> project
>> vs. a website in VS-2005.
>> View this message in context:
>> http://www.nabble.com/1.2-using-.net-2.0-and-VS2005-and-web-application-project-tf4470343s16610.html#a12746130
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/1.2-using-.net-2.0-and-VS2005-and-web-application-project-tf4470343s16610.html#a12749529
