[mapguide-users] MGOS 1.2.0 Filter On Joined Field
Jorge Rubio j.e.rubio at gmail.com
Wed Sep 19 12:40:56 EDT 2007
2007/9/19, James Card <James.Card at calcad.com>:
> On Wed, 19 Sep 2007 09:01:54 -0700, Jorge Rubio <j.e.rubio at gmail.com>
> wrote:
> > What are you trying to do?
> > Do you want filter data in Studio to set properties values to layers?
> > Do you want filter data by code -inside an application- to modify
> What we need to do is store the geometries in SDF files and then display
> only the polygons from that SDF where the matching database record has
> some value. For example, in this layer display only the rooms where
> TYPE='LAB' and SIZE<300. This works fine as long as all the data is stored
> in the SDF, but we can't filter on fields from a joined table (even though
> the fields from the joined table are visible in the Properties pane, so we
> know the join is working).
> James Card
> 209-578-5580
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Lic. Jorge Rubio
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070919/d5ce8e37/attachment.html
