[mapguide-users] How to prepare the unmanaged feature source?
Carl carlshe at 163.com
Thu Sep 20 11:31:41 EDT 2007
OK. It works. Thank everybody.
Kenneth, GEOGRAF A/S wrote:
> That won't work.
> The filename  "[CADFiles]PrjLines.sdf" is not valid.
> Try something like C:\CadFiles\PrjLines.sdf", and adjust to the actual
> location.
> Regards, Kenneth, GEOGRAF A/S
> Carl skrev:
>> I have download a featuresource xml and modified it as follows.
>> <?xml version="1.0" encoding="utf-8" ?>
>> <FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>> xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
>>   <Provider>OSGeo.SDF</Provider>
>> <Parameter>
>>   <Name>File</Name>
>>   <Value>[CADFiles]PrjLines.sdf</Value>
>>   </Parameter>
>> <Parameter>
>>   <Name>ReadOnly</Name>
>>   <Value>TRUE</Value>
>>   </Parameter>
>>   </FeatureSource>
>> Then I upload the new xml with mapagent. But the feature can't be shown
>> with
>> MG OS 1.2. When visiting the layer defined based on this feature with
>> Asdk
>> Studio 2007,  a popup is shown with:
>>   The featuresource is invalid.
>>   An exception occured in FDO Component.
>>   SDF connect failed. File doesnot exist or cannot be opened in specified
>> access mode.
>>> To get the actual mapping for an existing featuresource, you can
>>> download the Xml for an existing FeatureSource, either in Studio or
>>> through the http interface:
>>> http://localhost/mapguide/mapagent/index.html
>>> Choose the "Resource" and "GetResourceContent"
>>> The "unmanaged" refers to the fact that the resource files are not
>>> inside the repository.
>>> So, to make the featuresource unmanaged, modify one of the [Parameter
>>> Value] strings to point to an external datasource.
>>> Jackie Ng skrev:
>>>> A basic FeatureSource document looks like something below...
>>>> <?xml version="1.0"?>
>>>> <FeatureSource xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
>>>>      <Provider>[Name of the provider]</Provider>
>>>>      <Parameter>
>>>>            <Name>[Connection Parameter]</Name>
>>>>            <Value>[Parameter Value]</Value>
>>>>      </Parameter>
>>>>      <Parameter>
>>>>      </Parameter>
>>>>      <Parameter>
>>>>      </Parameter>
>>>> </FeatureSource>
>>>> [Name of the provider] is the name of the provider (eg. OSGeo.SDF,
>>>> OSGeo.SHP, etc)
>>>> To determine what parameters are required. invoke the
>>>> GetConnectPropertyValues of the Feature Service in your mapagent.
>>>> - Jackie
>>>> Carl wrote:
>>>>> Can somebody share a XML example of an unmanaged feature source
>>>>> definition?
>>>>>> Afaik, there is no template.
>>>>>> To use the "unmanaged feature source" feature, you must have a server
>>>>>> of
>>>>>> build 1.2 or greater (Enterprise 2008 is roughly 1.2 Beta2).
>>>>>> Sencondly the unmanaged feature is avalible but not displayed in
>>>>>> Studio
>>>>>> 2007.
>>>>>> You will have to upgrade if you want it displayed in Studio.
>>>>>> You can setup an unmanaged directory, using the "Site Administrator"
>>>>>> (there is a menu for opening the site administrator in Studio).
>>>>>> Once the folder is setup, you can use it from within Studio 2008.
>>>>>> If you use Studio 2007, you must manually edit the FeatureSource xml
>>>>>> file, and change the path to something like:
>>>>>> %MG_DATA_PATH_ALIAS[name of alias]%/name of datafile.sdf
>>>>>> You will probably have to restart both the server and studio if you
>>>>>> add
>>>>>> or remove an alias.
>>>>>> If you don't want the alias option, but just reference data outside
>>>>>> of
>>>>>> the repository, you can manually edit the FeatureSource xml, to point
>>>>>> at
>>>>>> the correct data.
>>>>>> Carl skrev:
>>>>>>> Where I can find the template of unmanaged featuresource, or layer?
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> mapguide-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/How-to-prepare-the-unmanaged-feature-source--tf4408812s16610.html#a12799640
