[mapguide-users] How to prepare the unmanaged feature source?
Kenneth, GEOGRAF A/S
ks at geograf.dk
Tue Sep 11 03:39:27 EDT 2007
That won't work.
The filename "[CADFiles]PrjLines.sdf" is not valid.
Try something like C:\CadFiles\PrjLines.sdf", and adjust to the actual
location.
Regards, Kenneth, GEOGRAF A/S
Carl skrev:
> I have download a featuresource xml and modified it as follows.
> <?xml version="1.0" encoding="utf-8" ?>
> <FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
> <Provider>OSGeo.SDF</Provider>
> <Parameter>
> <Name>File</Name>
> <Value>[CADFiles]PrjLines.sdf</Value>
> </Parameter>
> <Parameter>
> <Name>ReadOnly</Name>
> <Value>TRUE</Value>
> </Parameter>
> </FeatureSource>
> Then I upload the new xml with mapagent. But the feature can't be shown with
> MG OS 1.2. When visiting the layer defined based on this feature with Asdk
> Studio 2007, a popup is shown with:
> The featuresource is invalid.
> An exception occured in FDO Component.
> SDF connect failed. File doesnot exist or cannot be opened in specified
> access mode.
> Kenneth, GEOGRAF A/S wrote:
>> To get the actual mapping for an existing featuresource, you can
>> download the Xml for an existing FeatureSource, either in Studio or
>> through the http interface:
>> http://localhost/mapguide/mapagent/index.html
>> Choose the "Resource" and "GetResourceContent"
>> The "unmanaged" refers to the fact that the resource files are not
>> inside the repository.
>> So, to make the featuresource unmanaged, modify one of the [Parameter
>> Value] strings to point to an external datasource.
>> Jackie Ng skrev:
>>> A basic FeatureSource document looks like something below...
>>> <?xml version="1.0"?>
>>> <FeatureSource xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
>>> <Provider>[Name of the provider]</Provider>
>>> <Parameter>
>>> <Name>[Connection Parameter]</Name>
>>> <Value>[Parameter Value]</Value>
>>> </Parameter>
>>> <Parameter>
>>> </Parameter>
>>> <Parameter>
>>> </Parameter>
>>> </FeatureSource>
>>> [Name of the provider] is the name of the provider (eg. OSGeo.SDF,
>>> OSGeo.SHP, etc)
>>> To determine what parameters are required. invoke the
>>> GetConnectPropertyValues of the Feature Service in your mapagent.
>>> - Jackie
>>> Carl wrote:
>>>> Can somebody share a XML example of an unmanaged feature source
>>>> definition?
>>>>> Afaik, there is no template.
>>>>> To use the "unmanaged feature source" feature, you must have a server
>>>>> of
>>>>> build 1.2 or greater (Enterprise 2008 is roughly 1.2 Beta2).
>>>>> Sencondly the unmanaged feature is avalible but not displayed in Studio
>>>>> 2007.
>>>>> You will have to upgrade if you want it displayed in Studio.
>>>>> You can setup an unmanaged directory, using the "Site Administrator"
>>>>> (there is a menu for opening the site administrator in Studio).
>>>>> Once the folder is setup, you can use it from within Studio 2008.
>>>>> If you use Studio 2007, you must manually edit the FeatureSource xml
>>>>> file, and change the path to something like:
>>>>> %MG_DATA_PATH_ALIAS[name of alias]%/name of datafile.sdf
>>>>> You will probably have to restart both the server and studio if you add
>>>>> or remove an alias.
>>>>> If you don't want the alias option, but just reference data outside of
>>>>> the repository, you can manually edit the FeatureSource xml, to point
>>>>> at
>>>>> the correct data.
>>>>> Carl skrev:
>>>>>> Where I can find the template of unmanaged featuresource, or layer?
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070911/54686196/attachment.html
