[mapguide-users] How to prepare the unmanaged feature source?
Carl carlshe at 163.com
Mon Sep 10 13:00:58 EDT 2007
I have download a featuresource xml and modified it as follows.
<?xml version="1.0" encoding="utf-8" ?>
<FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
  <Provider>OSGeo.SDF</Provider>
<Parameter>
  <Name>File</Name>
  <Value>[CADFiles]PrjLines.sdf</Value>
  </Parameter>
<Parameter>
  <Name>ReadOnly</Name>
  <Value>TRUE</Value>
  </Parameter>
  </FeatureSource>
Then I upload the new xml with mapagent. But the feature can't be shown with
MG OS 1.2. When visiting the layer defined based on this feature with Asdk
Studio 2007,  a popup is shown with:
  The featuresource is invalid.
  An exception occured in FDO Component.
  SDF connect failed. File doesnot exist or cannot be opened in specified
access mode.
Kenneth, GEOGRAF A/S wrote:
> To get the actual mapping for an existing featuresource, you can
> download the Xml for an existing FeatureSource, either in Studio or
> through the http interface:
> http://localhost/mapguide/mapagent/index.html
> Choose the "Resource" and "GetResourceContent"
> The "unmanaged" refers to the fact that the resource files are not
> inside the repository.
> So, to make the featuresource unmanaged, modify one of the [Parameter
> Value] strings to point to an external datasource.
> Regards, Kenneth, GEOGRAF A/S
> Jackie Ng skrev:
>> A basic FeatureSource document looks like something below...
>> <?xml version="1.0"?>
>> <FeatureSource xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
>>      <Provider>[Name of the provider]</Provider>
>>      <Parameter>
>>            <Name>[Connection Parameter]</Name>
>>            <Value>[Parameter Value]</Value>
>>      </Parameter>
>>      <Parameter>
>>      </Parameter>
>>      <Parameter>
>>      </Parameter>
>> </FeatureSource>
>> [Name of the provider] is the name of the provider (eg. OSGeo.SDF,
>> OSGeo.SHP, etc)
>> To determine what parameters are required. invoke the
>> GetConnectPropertyValues of the Feature Service in your mapagent.
>> - Jackie
>> Carl wrote:
>>> Can somebody share a XML example of an unmanaged feature source
>>> definition?
>>>> Afaik, there is no template.
>>>> To use the "unmanaged feature source" feature, you must have a server
>>>> of
>>>> build 1.2 or greater (Enterprise 2008 is roughly 1.2 Beta2).
>>>> Sencondly the unmanaged feature is avalible but not displayed in Studio
>>>> 2007.
>>>> You will have to upgrade if you want it displayed in Studio.
>>>> You can setup an unmanaged directory, using the "Site Administrator"
>>>> (there is a menu for opening the site administrator in Studio).
>>>> Once the folder is setup, you can use it from within Studio 2008.
>>>> If you use Studio 2007, you must manually edit the FeatureSource xml
>>>> file, and change the path to something like:
>>>> %MG_DATA_PATH_ALIAS[name of alias]%/name of datafile.sdf
>>>> You will probably have to restart both the server and studio if you add
>>>> or remove an alias.
>>>> If you don't want the alias option, but just reference data outside of
>>>> the repository, you can manually edit the FeatureSource xml, to point
>>>> at
>>>> the correct data.
>>>> Carl skrev:
>>>>> Where I can find the template of unmanaged featuresource, or layer?
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/How-to-prepare-the-unmanaged-feature-source--tf4408812s16610.html#a12597808
