[mapguide-users] Reduce PNG image genate whit Tile Base Layer
Traian Stanev traian.stanev at autodesk.com
Fri Sep 21 15:59:11 EDT 2007
Hi Maciej,
If you raster contains an aerial photo, it will not compress well with PNG. May be JPG would compress better?
Traian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
> bounces at lists.osgeo.org] On Behalf Of Maciej Skorczewski
> Sent: Friday, September 21, 2007 3:40 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Reduce PNG image genate whit Tile Base Layer
> hi
> is there any solution to reduce size of PNG generate whit TileBase
> Layer
>   in MG Open Source 1.2?
> Can i change default compresion level of this?
> In my aplication i store big raster (about 2GB), when i use TileBase
> Layer i see that it works faster but size of each PNG is about
> 50kb-130kb...it is to much.
> Maciej Skórczewski
> mapguide-users mailing list
