[mapguide-users] Tiling and other methods to improve performance
George McLean gmclean at gorge.net
Mon Sep 24 15:36:29 EDT 2007
Hi Kori,
If I change the ImageFormat setting in serverconfig.ini from PNG to JPG
will the tiling engine create JPG images?
Thanks
George McLean
Kori Maleski wrote:
> It does, but there may be issues.
> ________________________________
> Kori Maleski
> Senior Application Developer
> WEBSOFT DEVELOPERS, INC.
> P: (530) 759-8754 ext 114
> F: (530) 759-0923
> kori.maleski at websoftdev.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Berdel, Brian
> Sent: Monday, September 24, 2007 11:33 AM
> To: MapGuide Users Mail List
> Subject: RE: [mapguide-users] Tiling and other methods to improve
> performance
> Ok, Thanks. I thought I read in another thread that switching the DLL's
> and webconfig.ini would allow it to work with 1.2
> Brian  Berdel
> McMahon Associates, Inc.
> p: 215.283.9444
> www.mcmtrans.com
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kori
> Maleski
> Sent: Monday, September 24, 2007 2:33 PM
> To: 'MapGuide Users Mail List'
> performance
> Working on MGO 1.2/ MGE2008 Release.  Will have it up shortly.
> Kori Maleski
> F: (530) 759-0923
> Brian
> Sent: Monday, September 24, 2007 10:55 AM
> performance
> I have a repeating error when I try to use the tilingengine
> Title: Error
> Message: Resource data was not found: LayerGroupData
> StackTrace: Resource data was not found: LayerGroupData
> Exception occurred in method MgTagManager.GetTag at line 395 in file
> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src
> \services\resource\TagManager.cpp
> Date/Time: 9/24/2007 1:52:08 PM
> I am using 1.2
> C:\Program Files\Websoft Developers\FacilitiesMap Tiling
> Engine>"C:\Program File
> s\Websoft Developers\FacilitiesMap Tiling Engine\FmTilingEngine.exe" -u
> Administ
> rator -p admin -m SoleburyTwp
>      Release Version 1.0.0
>      -u user:    Administrator
>      -p password:***********
>      -m map:    SoleburyTwp
>      -g group    not specified
>      -s scale    not specified
>      -sx         not specified
>      -sy         not specified
>      -ex         not specified
>      -ey         not specified
>      -l log      not specified
>  Preparing to Tile 'SoleburyTwp' Map Definition...
>  Initializing Connection to MapGuide...Succeeded
>  Tiling 'Base Layer Group' Layer Group...
>  Scale: 1:98000   Finite Scale 1 of 12
>  Tiles: 20 ( 5 Columns x 4 Rows )
>  ...1...2...3
> Brian  Berdel
> p: 215.283.9444
> www.mcmtrans.com
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of George
> McLean
> Sent: Thursday, September 20, 2007 11:26 AM
> Subject: Re: [mapguide-users] Tiling and other methods to improve
> performance
> Thanks again Kori. I will be upgrading today and hopefully will see
> beautiful panning maps!
> George
> Kori Maleski wrote:
>> George,
>> Upgrade to 1.2, since the tiled maping/base layer performance is much
>> better.
>> Then use the tiling engine to pre-tile just the area of interest at
> large
>> scales.  Small scales you may tile the whole thing.
>> This will reduce the number of tiles significantly.
>> The tiling engine allows you to specify a bounding box in tile
> row/columns.
>> If you specify these bounds you can limit the tile generation to
> required
>> areas only.  This will have to be done for each zoom threshold -
> easily done
>> with a batch script.
>> I generated a tiled base map for the entire state of California in
> this
>> manner.  I tiled the entirety of all the small scale thresholds and
> then
>> just specific areas of interest (urban centres) at large scale
> thresholds.
>> To reduce tiles (and the amount of space they require) - try to reduce
> the
>> number of thresholds.  Some may be unnecessary.
>> Cheers,
>> Kori Maleski
>> F: (530) 759-0923
> McLean
>> Sent: Wednesday, September 19, 2007 3:32 PM
>> Subject: [mapguide-users] Tiling and other methods to improve
> performance
>> Hello,
>> I have a large base map that covers an area for an electric utility.
> The
>> base map is in state plane grid coordinates and the map is about 100
>> miles in both X and Y. Most of this map in this 100x100 region is
> blank
>> since we only have base information near where the utility's
> facilities
>> are located. I am trying to improve performance by using tiles. I
> would
>> like to have zoom levels in pretty close, maybe on the order of 1:500
> as
>> well as zoom levels that much farther out. If I set this up with Base
>> Layers in studio and then generate tiles using Websoft's tiling engine
>> for each zoom level, I will get a huge number of tiles. If I do not
>> generate tiles then performance is perceived as poor.
>> Are there any better strategies for dealing with large base maps that
>> must be viewed both at the detail level and high zoom scales? I m
> still
>> using MGOS 1.1 (maybe I should upgrade).
>> Thanks,
>> George McLean
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
